Hello Everyone,
I am new to Ignition Dockers. I have setup two Ignition Gateways within a docker container. I have tried connecting the Ignition Gateways via OPC-UA to Kepware on my laptop in order to setup a testing environment. However, I am not able to connect as I receive the below error.
UaException: status=Bad_ConnectionRejected, message=io.netty.channel.AbstractChannel$AnnotatedConnectException: Connection refused: /192.168.1.95:49320
I have tried changing my OPC UA server settings and the bind address to 0.0.0.0. I have the trust certificates in both Kepware and the the Ignition Gateway enabled. I opened the Windows firewall port 49320 on my laptop for Kepware.
How can I connect to Kepware via OPC UA using a Ignition Gateway from a docker container?
Thank you for your help everyone,
