Like it says in the title, my gateway won’t start even though the webserver is starting just fine. It’s like the gateway is stuck in a permanent loop. I have tried restarting it many times and even left it as starting overnight with no results. Here is my wrapper log. I am not seeing any error codes
STATUS | wrapper | 2018/06/21 10:00:47 | Found #include file in C:\Program Files (x86)\Inductive Automation\Ignition\data\ignition.conf: ./wrapper-license.conf
STATUS | wrapper | 2018/06/21 10:00:47 | Reading included configuration file, C:\Program Files (x86)\Inductive Automation\Ignition\wrapper-license.conf
DEBUG | wrapper | 2018/06/21 10:00:47 | active log file changed: logs\wrapper.log
STATUS | wrapper | 2018/06/21 10:00:47 | --> Wrapper Started as Service
DEBUG | wrapper | 2018/06/21 10:00:47 | Allocating a console for the service.
DEBUG | wrapper | 2018/06/21 10:00:47 | Found console window.
STATUS | wrapper | 2018/06/21 10:00:47 | Java Service Wrapper Standard Edition 32-bit 3.5.29
STATUS | wrapper | 2018/06/21 10:00:47 | Copyright (C) 1999-2016 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2018/06/21 10:00:47 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2018/06/21 10:00:47 | Licensed to Inductive Automation for Inductive Automation
DEBUG | wrapper | 2018/06/21 10:00:47 | Launching Startup thread.
DEBUG | wrapper | 2018/06/21 10:00:47 | Startup thread started.
DEBUG | wrapper | 2018/06/21 10:00:47 | Attempting to verify the binary signature.
DEBUG | wrapper | 2018/06/21 10:00:47 | The file "C:\Program Files (x86)\Inductive Automation\Ignition\IgnitionGateway.exe" is not signed.
DEBUG | wrapper | 2018/06/21 10:00:47 | Startup thread stopped.
DEBUG | wrapper | 2018/06/21 10:00:47 | Release time: 2016/03/11 00:00:00
DEBUG | wrapper | 2018/06/21 10:00:47 | Build time: 2016/03/11 14:10:00
DEBUG | wrapper | 2018/06/21 10:00:47 | Timezone: US Mountain Standard Time (US Mountain Daylight Time) Offset: 25200, hasDaylight: 0
DEBUG | wrapper | 2018/06/21 10:00:47 | Using tick timer.
DEBUG | wrapper | 2018/06/21 10:00:47 | PID: 8116
DEBUG | wrapper | 2018/06/21 10:00:47 | System Language for non-unicode programs reports language Id: 0x0409 (Pri: 0x09, Sub: 0x01)
DEBUG | wrapper | 2018/06/21 10:00:47 | System code page: 1252 (ANSI - Latin I) (1252)
DEBUG | wrapper | 2018/06/21 10:00:47 | System UI language for the current user reports language Id: 0x0409 (Pri: 0x09, Sub: 0x01)
DEBUG | wrapper | 2018/06/21 10:00:47 | Language resolved to: en_US.UTF-8
DEBUG | wrapper | 2018/06/21 10:00:47 | Current User: opcuser Domain: USCHD01OPC01V
DEBUG | wrapper | 2018/06/21 10:00:47 | Operating System ID: Microsoft Windows Server 2012 R2 Standard Edition (build 9600), 64-bit
DEBUG | wrapper | 2018/06/21 10:00:47 | Environment variables (Source | Name=Value) BEGIN:
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | ALLUSERSPROFILE=C:\ProgramData
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | APPDATA=C:\Users\opcuser\AppData\Roaming
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | CommonProgramFiles=C:\Program Files (x86)\Common Files
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | CommonProgramW6432=C:\Program Files\Common Files
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | COMPUTERNAME=USCHD01OPC01V
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | ComSpec=C:\Windows\system32\cmd.exe
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | FP_NO_HOST_CHECK=NO
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | HOMEDRIVE=C:
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | HOMEPATH=\Users\opcuser
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | LANG=en_US.UTF-8.UTF-8
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | LOCALAPPDATA=C:\Users\opcuser\AppData\Local
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | LOGONSERVER=\\USCHD01OPC01V
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | NUMBER_OF_PROCESSORS=4
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | OS=Windows_NT
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | Path=C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\DTS\Binn\;C:\Program Files\Microsoft SQL Server\140\DTS\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\ManagementStudio\;C:\Program Files (x86)\Inductive Automation\Ignition
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PROCESSOR_ARCHITECTURE=x86
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PROCESSOR_ARCHITEW6432=AMD64
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 79 Stepping 1, GenuineIntel
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PROCESSOR_LEVEL=6
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PROCESSOR_REVISION=4f01
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | ProgramData=C:\ProgramData
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | ProgramFiles=C:\Program Files (x86)
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | ProgramFiles(x86)=C:\Program Files (x86)
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | ProgramW6432=C:\Program Files
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\PowerShell\Modules\
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | PUBLIC=C:\Users\Public
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | SystemDrive=C:
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | SystemRoot=C:\Windows
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | TEMP=C:\Users\opcuser\AppData\Local\Temp
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | TMP=C:\Users\opcuser\AppData\Local\Temp
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | USERDOMAIN=USCHD01OPC01V
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | USERDOMAIN_ROAMINGPROFILE=USCHD01OPC01V
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | USERNAME=opcuser
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | USERPROFILE=C:\Users\opcuser
DEBUG | wrapper | 2018/06/21 10:00:47 | P---- | windir=C:\Windows
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_ARCH=x86
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_BIN_DIR=C:\Program Files (x86)\Inductive Automation\Ignition
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_BITS=32
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_CONF_DIR=C:\Program Files (x86)\Inductive Automation\Ignition\data
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_FILE_SEPARATOR=\
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_HOST_NAME=USCHD01OPC01V
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_HOSTNAME=USCHD01OPC01V
DEBUG | wrapper | 2018/06/21 10:00:47 | P--W- | WRAPPER_INIT_DIR=C:\Windows\system32
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_LANG=en
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_OS=windows
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_PATH_SEPARATOR=;
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_PID=8116
DEBUG | wrapper | 2018/06/21 10:00:47 | ---W- | WRAPPER_WORKING_DIR=C:\Program Files (x86)\Inductive Automation\Ignition
DEBUG | wrapper | 2018/06/21 10:00:47 | Environment variables END:
DEBUG | wrapper | 2018/06/21 10:00:47 | Use tick timer mutex=FALSE
DEBUG | wrapper | 2018/06/21 10:00:47 | Preparing to restart with mode 1.
DEBUG | wrapperp | 2018/06/21 10:00:47 | server listening on port 32000.
DEBUG | wrapper | 2018/06/21 10:00:47 | Loaded java home from registry: C:\Program Files (x86)\Java\jre1.8.0_172
DEBUG | wrapper | 2018/06/21 10:00:47 | Found Java Runtime Environment home directory in system registry.
DEBUG | wrapper | 2018/06/21 10:00:47 | Magic number for file C:\Program Files (x86)\Java\jre1.8.0_172\bin\java.exe: 0x4d5a9000
DEBUG | wrapper | 2018/06/21 10:00:47 | Startup Timeouts: wrapper.startup.timeout=30, wrapper.startup.delay.console=0, wrapper.startup.delay.service=0, wrapper.restart.delay=5
DEBUG | wrapper | 2018/06/21 10:00:47 | Ping settings: wrapper.ping.interval=5, wrapper.ping.interval.logged=1, wrapper.ping.timeout=30, wrapper.ping.alert.threshold=7
DEBUG | wrapper | 2018/06/21 10:00:47 | Shutdown Timeouts: wrapper.shutdown.timeout=120, wrapper.jvm_exit.timeout=120, wrapper.jvm_cleanup.timeout=10, wrapper.jvm_terminate.timeout=10
STATUS | wrapper | 2018/06/21 10:00:47 | Launching a JVM...
DEBUG | wrapper | 2018/06/21 10:00:47 | Java Command Line:
DEBUG | wrapper | 2018/06/21 10:00:47 | Command: "C:\Program Files (x86)\Java\jre1.8.0_172\bin\java.exe" -XX:+CMSClassUnloadingEnabled -Ddata.dir=data -Dorg.apache.catalina.loader.WebappClassLoader.ENABLE_CLEAR_REFERENCES=false -Dfile.encoding=Cp1252 -Duser.language=en -Xms896m -Xmx896m -Djava.library.path="lib" -classpath "lib/wrapper.jar;lib/catapult.jar" -Dwrapper.key="g9HLtkY6fxc8IJx3V2uMKfDNjOBQxd1V" -Dwrapper.port=32000 -Dwrapper.jvm.port.min=31000 -Dwrapper.jvm.port.max=31999 -Dwrapper.debug="TRUE" -Dwrapper.pid=8116 -Dwrapper.version="3.5.29-st" -Dwrapper.native_library="wrapper" -Dwrapper.arch="x86" -Dwrapper.service="TRUE" -Dwrapper.cpu.timeout="10" -Dwrapper.jvmid=1 -Dwrapper.lang.domain="wrapper" -Dwrapper.lang.folder="../lang" org.tanukisoftware.wrapper.WrapperSimpleApp com.inductiveautomation.catapult.Catapult nopause
DEBUG | wrapper | 2018/06/21 10:00:47 | JVM started (PID=3896)
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: WrapperManager class initialized by thread: main Using classloader: sun.misc.Launcher$AppClassLoader@647e05
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager: Initializing...
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: JVM #1
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Running a 32-bit JVM.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: org.tanukisoftware.wrapper.WrapperManager package information:
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Implementation Title: org.tanukisoftware.wrapper
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Implementation Vendor: Tanuki Software, Ltd.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Implementation Version: 3.5.29
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Is Sealed?: False
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: org.tanukisoftware.wrapper.WrapperManager protection domain:
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Location: file:/C:/Program%20Files%20(x86)/Inductive%20Automation/Ignition/lib/wrapper.jar
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Size: 124,014
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: MD5: 0bf94d5481156cfd1165af04f5843c40
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Registering shutdown hook
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Using wrapper
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Registered MBean with Platform MBean Server: org.tanukisoftware.wrapper:type=WrapperManager
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Load native library. There are multiple possible file names and the first to be found will be used. Errors loading non-existing files is normal and is only a problem if they all fail.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Attempt to load native library with name: wrapper-windows-x86-32.dll Result: Success!
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Successfully loaded native library.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Loaded localized resources.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Calling native initialization method.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperJNI Debug: Initializing WrapperManager native library.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperJNI Debug: Java Executable: C:\Program Files (x86)\Java\jre1.8.0_172\bin\java.exe
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperJNI Debug: Native Library: C:\Program Files (x86)\Inductive Automation\Ignition\lib\wrapper-windows-x86-32.dll
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperJNI Debug: Windows version: 6.3.9600
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Java PID : 3896
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Java Version : 1.8.0_172-b11 Java HotSpot(TM) Client VM
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Java VM Vendor : Oracle Corporation
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: OS Name : Windows Server 2012 R2
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: OS Arch : x86
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Control event monitor thread started.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Startup runner thread started.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: WrapperManager.start(a org.tanukisoftware.wrapper.WrapperSimpleApp, args["nopause"]) called by thread: main
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Initial thread: main Priority: 5
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Communications runner thread started.
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Open socket to wrapper...Wrapper-Connection
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Opened Socket from 31,000 to 32,000
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: Send a packet KEY : g9HLtkY6fxc8IJx3V2uMKfDNjOBQxd1V
INFO | jvm 1 | 2018/06/21 10:00:48 | WrapperManager Debug: handleBackend()
DEBUG | wrapperp | 2018/06/21 10:00:48 | accepted a socket on port 32000 from 127.0.0.1 at port 31000
DEBUG | wrapperp | 2018/06/21 10:00:48 | closing backend server.
DEBUG | wrapperp | 2018/06/21 10:00:48 | read a packet KEY : g9HLtkY6fxc8IJx3V2uMKfDNjOBQxd1V
DEBUG | wrapper | 2018/06/21 10:00:48 | Got key from JVM: g9HLtkY6fxc8IJx3V2uMKfDNjOBQxd1V
DEBUG | wrapperp | 2018/06/21 10:00:48 | Send a packet LOW_LOG_LEVEL : 1
DEBUG | wrapperp | 2018/06/21 10:00:48 | Send a packet LOGFILE : logs\wrapper.log
DEBUG | wrapperp | 2018/06/21 10:00:48 | Send a packet PROPERTIES : (Property Values, Size=4138)
DEBUG | wrapper | 2018/06/21 10:00:48 | Start Application.
DEBUG | wrapperp | 2018/06/21 10:00:48 | Send a packet START : start
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: Received a packet LOW_LOG_LEVEL : 1
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: LowLogLevel from Wrapper is 1
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: Received a packet LOGFILE : logs\wrapper.log
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: Received a packet PROPERTIES : (Property Values, Size=4138)
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: Received a packet START : start
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: Java temporary directory: C:\Users\opcuser\AppData\Local\Temp
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: calling WrapperListener.start()
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: WrapperListener.start runner thread started.
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperManager Debug: Application start main thread: WrapperListener_start_runner Priority: 5
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperSimpleApp Debug: start(args) Will wait up to 2 seconds for the main method to complete.
INFO | jvm 1 | 2018/06/21 10:00:49 | WrapperSimpleApp Debug: invoking main method
INFO | jvm 1 | 2018/06/21 10:00:49 | 10:00:49,115 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\\logback.xml] at [file:/C:/Program%20Files%20(x86)/Inductive%20Automation/Ignition/data/logback.xml]
INFO | jvm 1 | 2018/06/21 10:00:49 | 10:00:49,490 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2018/06/21 10:00:49 | 10:00:49,490 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2018/06/21 10:00:49 | 10:00:49,506 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2018/06/21 10:00:49 | 10:00:49,553 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2018/06/21 10:00:49 | 10:00:49,568 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2018/06/21 10:00:50 | WrapperManager Debug: Send a packet START_PENDING : 5000
DEBUG | wrapperp | 2018/06/21 10:00:50 | read a packet START_PENDING : 5000
DEBUG | wrapper | 2018/06/21 10:00:50 | JVM signaled a start pending with waitHint of 5000 millis.
INFO | jvm 1 | 2018/06/21 10:00:50 | WrapperSimpleApp Debug: start(args) end. Main Completed=false, exitCode=null
INFO | jvm 1 | 2018/06/21 10:00:50 | WrapperManager Debug: returned from WrapperListener.start()
INFO | jvm 1 | 2018/06/21 10:00:50 | WrapperManager Debug: Send a packet STARTED :
INFO | jvm 1 | 2018/06/21 10:00:50 | WrapperManager Debug: WrapperListener.start runner thread stopped.
DEBUG | wrapperp | 2018/06/21 10:00:50 | read a packet STARTED :
DEBUG | wrapper | 2018/06/21 10:00:50 | JVM signaled that it was started.
INFO | jvm 1 | 2018/06/21 10:00:51 | WrapperManager Debug: Startup runner thread stopped.
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,225 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@b185e0 - Driver name=SQLite JDBC
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,225 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@b185e0 - Driver version=3.20.1
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,225 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@b185e0 - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,303 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,303 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,303 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,303 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,303 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,303 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,303 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,318 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,318 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,318 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,318 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,318 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,318 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2018/06/21 10:00:51 | 10:00:51,318 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@367039 - Registering current configuration as safe fallback point
INFO | jvm 1 | 2018/06/21 10:00:51 | Scheduling logfile maintenance. Last maintenance: Wed Dec 31 17:00:00 MST 1969, events since then: 0
INFO | jvm 1 | 2018/06/21 10:00:51 | Starting logfile maintenance. Max entries: 50000
INFO | jvm 1 | 2018/06/21 10:00:51 | I [o.e.j.u.log ] [17:00:51]: Logging initialized @3644ms
INFO | jvm 1 | 2018/06/21 10:00:51 | Cleaned up 1097 rows in 110 ms. Vacuum performed: false
INFO | jvm 1 | 2018/06/21 10:00:51 | I [o.e.j.s.Server ] [17:00:51]: jetty-9.3.z-SNAPSHOT
DEBUG | wrapperp | 2018/06/21 10:00:51 | Send a packet PING : ping fffffe2a
INFO | jvm 1 | 2018/06/21 10:00:51 | WrapperManager Debug: Received a packet PING : ping fffffe2a
INFO | jvm 1 | 2018/06/21 10:00:51 | WrapperManager Debug: Send a packet PING : ping fffffe2a
DEBUG | wrapperp | 2018/06/21 10:00:51 | read a packet PING : ping fffffe2a
INFO | jvm 1 | 2018/06/21 10:00:52 | I [o.e.j.w.StandardDescriptorProcessor] [17:00:52]: NO JSP Support for /main, did not find org.apache.jasper.servlet.JspServlet
INFO | jvm 1 | 2018/06/21 10:00:52 | I [c.i.i.g.b.SRClassLoader ] [17:00:52]: SRClassLoader init
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.Application ] [17:00:53]: [WicketFilter] init: Wicket core library initializer
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.RequestListenerInterface] [17:00:53]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.RequestListenerInterface] [17:00:53]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.RequestListenerInterface] [17:00:53]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.RequestListenerInterface] [17:00:53]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.RequestListenerInterface] [17:00:53]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.RequestListenerInterface] [17:00:53]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.Application ] [17:00:53]: [WicketFilter] init: Wicket extensions initializer
INFO | jvm 1 | 2018/06/21 10:00:53 | I [SRContext ] [17:00:53]: Ignition["/main", state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2018/06/21 10:00:53 | I [SRContext ] [17:00:53]: Starting Ignition 7.9.7 (b2018032914)
INFO | jvm 1 | 2018/06/21 10:00:53 | I [SRContext ] [17:00:53]: Reloading JDBC classloader.
INFO | jvm 1 | 2018/06/21 10:00:53 | W [SRContext ] [17:00:53]: Unable to read "catapult.metroKeystoreAlias" gateway.xml property. Assuming metro keystore alias is: metro-key
INFO | jvm 1 | 2018/06/21 10:00:53 | I [C.SecureRandomProvider ] [17:00:53]: Creating SecureRandom object...
INFO | jvm 1 | 2018/06/21 10:00:53 | I [C.SecureRandomProvider ] [17:00:53]: ... SecureRandom Created.
INFO | jvm 1 | 2018/06/21 10:00:53 | I [C.SecureRandomProvider ] [17:00:53]: Secure random seed generated in 1ms
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.a.w.p.h.WebApplication ] [17:00:53]: [WicketFilter] Started Wicket version 6.1.1 in DEPLOYMENT mode
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.e.j.s.h.ContextHandler ] [17:00:53]: Started o.e.j.w.WebAppContext@bac42d{/main,file:///C:/Program%20Files%20(x86)/Inductive%20Automation/Ignition/webserver/webapps/main/,AVAILABLE}
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.e.j.s.ServerConnector ] [17:00:53]: Started ServerConnector@1154f44{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO | jvm 1 | 2018/06/21 10:00:53 | I [R.StateMonitoring ] [17:00:53]: Redundancy state changed: Role=Independent, Activity level=Active, Project state=Good, History level=Full
INFO | jvm 1 | 2018/06/21 10:00:53 | I [o.e.j.u.s.SslContextFactory ] [17:00:53]: x509=X509@64db23(tomcat,h=[],w=[]) for SslContextFactory@f279c(file:///C:/Program%20Files%20(x86)/Inductive%20Automation/Ignition/webserver/ssl.key,null)
INFO | jvm 1 | 2018/06/21 10:00:53 | I [g.InternalDatabaseManager ] [17:00:53]: Starting up...
INFO | jvm 1 | 2018/06/21 10:00:53 | I [P.InternalDatabase ] [17:00:53]: Looking for existing internal database "config.idb"...
INFO | jvm 1 | 2018/06/21 10:00:53 | I [P.InternalDatabase ] [17:00:53]: ... found existing.
INFO | jvm 1 | 2018/06/21 10:00:53 | I [P.InternalDatabase ] [17:00:53]: internal database "config.idb" started up successfully.
INFO | jvm 1 | 2018/06/21 10:00:53 | I [P.InternalDatabase ] [17:00:53]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database "config.idb"]
INFO | jvm 1 | 2018/06/21 10:00:54 | I [SystemInfo ] [17:00:54]: os.name="windows server 2012 r2", os.arch="x86".
INFO | jvm 1 | 2018/06/21 10:00:54 | I [SystemInfo ] [17:00:54]: Validating native library "ignition32"...
INFO | jvm 1 | 2018/06/21 10:00:54 | I [SystemInfo ] [17:00:54]: Validated ignition32 (ignition32.dll)
INFO | jvm 1 | 2018/06/21 10:00:54 | I [SystemInfo ] [17:00:54]: Loading native library "ignition32"...
INFO | jvm 1 | 2018/06/21 10:00:54 | I [SystemInfo ] [17:00:54]: Native library load complete
INFO | jvm 1 | 2018/06/21 10:00:54 | I [g.ModuleManager ] [17:00:54]: Loading modules....
INFO | jvm 1 | 2018/06/21 10:00:55 | I [o.e.j.s.ServerConnector ] [17:00:55]: Started ServerConnector@2fac74{SSL,[ssl, http/1.1]}{0.0.0.0:8043}
INFO | jvm 1 | 2018/06/21 10:00:55 | I [o.e.j.s.ServerConnector ] [17:00:55]: Started ServerConnector@13ae8e8{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 1 | 2018/06/21 10:00:55 | I [o.e.j.s.Server ] [17:00:55]: Started @8252ms
DEBUG | wrapperp | 2018/06/21 10:00:56 | Send a packet PING : ping fffffe53
INFO | jvm 1 | 2018/06/21 10:00:56 | WrapperManager Debug: Received a packet PING : ping fffffe53
INFO | jvm 1 | 2018/06/21 10:00:56 | WrapperManager Debug: Send a packet PING : ping fffffe53
DEBUG | wrapperp | 2018/06/21 10:00:56 | read a packet PING : ping fffffe53
INFO | jvm 1 | 2018/06/21 10:00:58 | Received GetMainContextDetailsRequest...
INFO | jvm 1 | 2018/06/21 10:00:58 | ...returning GetMainContextDetailsResponse (0ms)
DEBUG | wrapperp | 2018/06/21 10:01:01 | Send a packet PING : ping fffffe7d
INFO | jvm 1 | 2018/06/21 10:01:01 | WrapperManager Debug: Received a packet PING : ping fffffe7d
INFO | jvm 1 | 2018/06/21 10:01:01 | WrapperManager Debug: Send a packet PING : ping fffffe7d
DEBUG | wrapperp | 2018/06/21 10:01:01 | read a packet PING : ping fffffe7d
INFO | jvm 1 | 2018/06/21 10:01:01 | I [A.Notification ] [17:01:01]: Alert notification system created.
INFO | jvm 1 | 2018/06/21 10:01:04 | I [g.ModuleManager ] [17:01:04]: Setting up modules
INFO | jvm 1 | 2018/06/21 10:01:04 | I [G.L.A.AlarmNotificationService] [17:01:04]: Remote Alarm Notification Manager initialized successfully.
INFO | jvm 1 | 2018/06/21 10:01:05 | I [c.i.o.ModuleHook ] [17:01:05]: JNI Library: C:\Users\opcuser\AppData\Local\Temp\__514443356__jniwrap-3.10.Build.3.108081dcca-22b7-42eb-af6e-dc741644899a\jniwrap.dll
DEBUG | wrapperp | 2018/06/21 10:01:05 | Send a packet PING : ping fffffea6
INFO | jvm 1 | 2018/06/21 10:01:05 | WrapperManager Debug: Received a packet PING : ping fffffea6
INFO | jvm 1 | 2018/06/21 10:01:05 | WrapperManager Debug: Send a packet PING : ping fffffea6
DEBUG | wrapperp | 2018/06/21 10:01:05 | read a packet PING : ping fffffea6
INFO | jvm 1 | 2018/06/21 10:01:06 | I [i.UserSourceManager ] [17:01:06]: Starting up...
INFO | jvm 1 | 2018/06/21 10:01:06 | I [AuditManager ] [17:01:06]: AuditManager starting up...
INFO | jvm 1 | 2018/06/21 10:01:06 | I [A.S.StorageManager ] [17:01:06]: Starting up...
INFO | jvm 1 | 2018/06/21 10:01:06 | I [A.N.NotificationManager ] [17:01:06]: Starting up...
INFO | jvm 1 | 2018/06/21 10:01:06 | I [O.DAServer[DeltaV AP01 OPC Client]] [17:01:06]: Server 'DeltaV AP01 OPC
