Ignition Historian Question
Hello,
I'm historizing one tag with Sample Mode as "On Change" and other parameters for History settings are as default.
However, When I tried to fetch the data for that tag, I am seeing multiple rows with different time stamp with the same value.
Tag Type: BOOLEAN
My question is why Ignition is historizing if the setting is Sample at "On Change" and values are same?
Thanks in advance!!!
I'm attaching screenshot for historized data
My Initial thoughts - your tag is changing in quality.
From the docs @ Configuring Tag History - Analog:
  • The system always stores a value when the quality on the tag changes.
