We have an issue with Ignition 7.9 where it now generates an HTTP 500 from the web site.
Error 500 java.lang.NoClassDefFoundError: com/inductiveautomation/ignition/gateway/web/components/LaunchLink$Applet
Gateway scripts are still running, but the tags are generated as Unknown. The script generates a CSV file every minutes.
I have installed the latest java runtime, no isssue fixed, not sure if Ignition is re-install what yould happen to my project of config files as the backup failed (No response received from Gateway. Verify that the gateway is running.)
No idea how to read the thread dump.
Any idea?
What version of 7.9 is it? That referenced class doesn’t even exist any more in later ones.
Hi Kevin,
7.9.14 (64 bit) From the Gateway control panel, the only thing that works.
Regards,
Can you get the wrapper logs and upload them? Might be easier to work with support, though I do suspect a gateway restart and/or upgrade would fix whatever is going on if you don’t care to troubleshoot.
Please help on getting the wrapper log, like how to get them.
Done the restart many times with the same result.
Upgrading? to what and will it gets the project and config without erasing them?
If possible, before an upgrade, it would be nice to get these files.
Thanks,
The logs are in the logs directory wherever Ignition was installed.
Call support and work with them to ensure you don’t lose any of your data.
Was this issue ever resolved? I am having the same issue after configuring the redundancy server for my site.
Are you on 7.9?
Some old support notes indicate this issue is related to upgrading a backup gateway before a the primary gateway, and the primary gateway receiving mismatched module versions or something like that.
Check the modules page for both gateways and make sure the module versions line up?
edit: seems that a gateway restart may be needed before the module version mismatch can be seen...
This is likely the issue, Primary is running 7.9.10, secondary is running 7.9.21. Both are being upgraded to the latest 8.1 tomorrow
(re) Install 7.9.21 on the primary for now.
Did that and it immediately fixed the issue, thank you
