Yes, if I understand you correctly you can place your images or folder of images inside the install directory of the gateway inside of <install_directory>/webserver/webapps/main and after a gateway restart they are hosted at http://localhost:8088/<path_to_image> and don’t forget to include the image extension in the path (ie. the .jpg, .png, etc)
Placing files in that path does allow my webbrowser to access the filename.jpg, but localhost won’t work from within ignition, i still need to define an external IP
Can you give me an example? Are you using this on an image component on Vision or Perspective? Also, when you have a session/client opened are they on the same system as the gateway since that’s the only time localhost should work?
