Ignition in Docker - Running same GW backups
Hi, I wanted to check with community, if someone can say that following setup could cause issues.
Me and my colleague run Ignition in Docker and (using the BWGroup image) we use the same gateway backup, this backup includes AD user sources set up, and EAM connection to another gateway that is used for remote tag provider.
We ran into a weird situation when both of us run the gateway, one or none of us can connect with designer to the local gateway in the container. The gateway is up and running in the browser. What the designer shows is status of the gateway is unknown and sometimes the timeout counter is not even counting and is stuck at 29s. I cannot add the gateway again manually, it keeps trying to find it.
Can there be an interference between these two gateways running the same gateway backup?
