Does anyone know if Ignition can use a Socks5 proxy for accessing the internet, and specifically for renewing\license management? This will be running on Windows.
Jason
Jason
You can do an offline activation:
https://docs.inductiveautomation.com/display/DOC81/Licensing+and+Activation#LicensingandActivation-OfflineActivationExample
Unless you're using leased licensing, but that's not the default, so you're probably fine with the standard offline activation flow.
