Hello!
Does Windows 7 starter support Ignition? and Windows 7 starter N?
Regards.
Hello!
Regards.
I honestly don’t know much about windows 7 starter. I did a quick Google search and got conflicting information about whether or not you can install Java on it - can you try and let us know?
Is possible install Java in Windows 7 starter:
answers.microsoft.com/en-us/wind … 8d8476716b
In short, if you can install Java you can run Ignition, don’t you?
Right, if you can install Java you can run Ignition.
I have a couple of systems using windows starter as clients and used for designer working without problems.
Great! thanks for your answers! ![]()
Sam
