I have Ignition Gateway and my SQL DB running on the same server but I haven’t been able to correct the time zone difference.
While my server shows the correct Date Time, Ignition Date Time is off by 3 hours. This is causing problems when using Transaction groups, it will save the incorrect time stamp and won’t match my server Date Time.
I tried changing my project properties Time zone but whatever value I assign to it the time stamp doesn’t change.
any ideas on how to correct the Date Time difference between my Ignition gateway and the server?
thank you!
