Is there a way to determine the Ignition installation path from a gateway script?
I guess this is a good start context.getServletContext().getRealPath('/')
Try:
import os
print os.getcwd()
Thanks again… that was easy.
Here is a class that I use to download activemq-all-xxx.jar from maven if not in lib/core/gateway.
AMQLibDownloader().Download('activemq-all')
from java.lang import Exception
from java.io import IOException
from java.nio.file import Paths
from java.net import URL
from org.apache.commons.io import FileUtils
import sys
import os
class AMQLibDownloader():
def __init__(self):
self._logger = system.util.getLogger('activemq.AMQLibDownloader')
self._localGatwayCoreRelativePathString = "//lib//core//gateway"
def _buildLatestMavenUrl(self,artifactId):
try:
searchUrl = "http://search.maven.org/solrsearch/select?q=%s&rows=1&wt=json" % artifactId
json = system.net.httpGet(searchUrl)
dict = system.util.jsonDecode(json)
artifact = dict['response']['docs'][0]
url = "http://%s.maven.org/maven2/%s/%s/%s/%s-%s.%s" \
% (artifact['repositoryId'],artifact['g'].replace('.','/'),artifact['a'],artifact['latestVersion'],artifact['a'],artifact['latestVersion'],artifact['p'])
return url, artifact
except Exception, ex:
self._logger.error("unable to build maven url for artifactId: '%s'" % artifactId)
self._logger.info(str(ex))
return None, None
def Download(self,artifactId,force=False):
mavenUrl, mavenArtifact = self._buildLatestMavenUrl(artifactId)
if mavenUrl is not None:
gatewayCorePath = Paths.get(os.getcwd() + self._localGatwayCoreRelativePathString)
libraryLocalPath = Paths.get(gatewayCorePath.toString() + "//%s-latest.%s" % (mavenArtifact['a'],mavenArtifact['p'])).toFile()
libraryRemotePath = URL(mavenUrl)
if not force:
if not system.file.fileExists(libraryLocalPath.toString()):
force = True
self._logger.warn("'%s' was not found" % libraryLocalPath.toString())
else:
pass
# get local SHA
# search maven by SHA
# compare local version against latest version
# update if mavent has newer version => set force=True
else:
self._logger.info("'%s' download forced" % libraryRemotePath.toString())
if force:
try:
self._logger.info("downloading '%s' => '%s'" % (libraryRemotePath.toString(), libraryLocalPath.toString()))
FileUtils.copyURLToFile(libraryRemotePath, libraryLocalPath)
sys.path.append(libraryLocalPath.toString()) #manual append until gateway is rebooted
self._logger.info('done')
except IOException, iex:
self._logger.error(iex)
self._logger.error(ex)
