Hi everyone,
I found this messagge in wrapper.log
INFO | jvm 1 | 2018/05/26 13:46:42 | I [g.InternalDatabaseManager ] [11:46:42]: Skipping schema feature 'INTERNAL_SQL_TAGS' for module 'UPDATE_SC_PROV_ID' - Does not apply to this db type.
INFO | jvm 1 | 2018/05/26 13:46:42 | I [g.InternalDatabaseManager ] [11:46:42]: Skipping schema feature 'INTERNAL_SQL_TAGS' for module 'INCREASE_STR_SIZE' - Does not apply to this db type.
INFO | jvm 1 | 2018/05/26 13:46:43 | W [T.P.DataTypes ] [11:46:43]: Invalid folder structure for UDT member. Tag cannot be added to hierarchy. Parent details may not be loaded yet, will try again if the udt parent is updated
What these mean?
thanks
