Error message:
"UaServiceFaultException: status=Bad_UserAccessDenied, message=User does not have permission to perform the requested operation.
at org.eclipse.milo.opcua.stack.transport.client.uasc.UascClientMessageHandler.onSecureMessage(UascClientMessageHandler.java:312)
at org.eclipse.milo.opcua.stack.transport.client.uasc.UascClientMessageHandler.decode(UascClientMessageHandler.java:269)
at io.netty.handler.codec.ByteToMessageCodec$1.decode(ByteToMessageCodec.java:42)
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:530)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:469)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:290)
at io.netty.handler.codec.ByteToMessageCodec.channelRead(ByteToMessageCodec.java:103)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:442)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:420)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:412)
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1357)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:440)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:868)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:166)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:796)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:732)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:658)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:562)
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:998)
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
at java.base/java.lang.Thread.run(Unknown Source)"
I tried: disabling and enabling the OPC UA server connection. Re-entering the default password “password”. Restarted the gateway. Reverted to a known working backup.
Tech support advised re-setting the default user (opcuauser) password (password) and disabling the OPC UA Module restarting the gateway, enabling the OPC UA module and restarting the gateway. Re-initialize the loopback connection.
this was the solution to getting the loopback OPC UA server working again for me.
