Ignition connects without problems at first but then the connection goes ‘faulted’. To connect again I have to delete the connection and make a new one with a different name. The version of Ignition is 7.3.4 32 bits for Windows. the java version is 1.6.0_16_b01. Her is a part of the wrapper.log
INFO | jvm 1 | 2012/03/22 08:56:29 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x80040202; CONNECT_E_ADVISELIMIT
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:744)
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:723)
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.jniwrapper.win32.ole.impl.IConnectionPointImpl.advise(SourceFile:93)
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.inductiveautomation.opccom.wrapper.shutdown.ServerShutdownDispatcher.advise(ServerShutdownDispatcher.java:52)
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:743)
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:47)
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:566)
INFO | jvm 1 | 2012/03/22 08:56:29 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:508)
INFO | jvm 1 | 2012/03/22 08:56:29 | INFO [COMServerImpl ] [08:56:29,640]: Server 'Wonderware' state set to [CONNECTED]
INFO | jvm 1 | 2012/03/22 08:56:48 | INFO [COMServerImpl ] [08:56:48,687]: COMServerImpl.Shutdown
INFO | jvm 1 | 2012/03/22 08:56:48 | INFO [COMServerImpl ] [08:56:48,687]: Disconnecting server 'Wonderware'
INFO | jvm 1 | 2012/03/22 08:56:48 | INFO [COMServerImpl ] [08:56:48,687]: Server 'Wonderware' state set to [CLOSED]
INFO | jvm 1 | 2012/03/22 08:57:37 | INFO [COMServerImpl ] [08:57:37,437]: COMServerImpl.Startup
INFO | jvm 1 | 2012/03/22 08:57:39 | INFO [COMServerImpl ] [08:57:39,453]: Server 'Wonderware' state set to [CONNECTING]
INFO | jvm 1 | 2012/03/22 08:57:39 | INFO [COMServerImpl ] [08:57:39,453]: Attempting to connect COM server 'Wonderware'
INFO | jvm 1 | 2012/03/22 08:57:39 | WARN [COMServerImpl ] [08:57:39,468]: Unable to advise server shutdown hook. Server may not support this functionality.
INFO | jvm 1 | 2012/03/22 08:57:39 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x80040202; CONNECT_E_ADVISELIMIT
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:744)
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:723)
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.jniwrapper.win32.ole.impl.IConnectionPointImpl.advise(SourceFile:93)
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.inductiveautomation.opccom.wrapper.shutdown.ServerShutdownDispatcher.advise(ServerShutdownDispatcher.java:52)
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:743)
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:47)
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:566)
INFO | jvm 1 | 2012/03/22 08:57:39 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:508)
INFO | jvm 1 | 2012/03/22 08:57:39 | INFO [COMServerImpl ] [08:57:39,468]: Server 'Wonderware' state set to [CONNECTED]
INFO | jvm 1 | 2012/03/22 08:59:25 | INFO [LocalDBManagerImpl ] [08:59:25,140]: Creating auto-backup of internal database "settings"...
INFO | jvm 1 | 2012/03/22 08:59:25 | INFO [ENGINE ] [08:59:25,171]: dataFileCache commit start
INFO | jvm 1 | 2012/03/22 08:59:25 | INFO [ENGINE ] [08:59:25,343]: Initiating backup of instance 'settings'
INFO | jvm 1 | 2012/03/22 08:59:25 | 1 / 4 settings.properties...
INFO | jvm 1 | 2012/03/22 08:59:25 | 2 / 4 settings.script...
INFO | jvm 1 | 2012/03/22 08:59:25 | 3 / 4 settings.data...
INFO | jvm 1 | 2012/03/22 08:59:25 | 4 / 4 settings.lobs...
INFO | jvm 1 | 2012/03/22 08:59:25 | INFO [ENGINE ] [08:59:25,562]: Successfully backed up instance 'settings' to 'C:\\Archivos de programa\\Inductive Automation\\Ignition\\data\\db\\autobackup\\db_20120322_085925.tar.gz'
INFO | jvm 1 | 2012/03/22 08:59:25 | INFO [LocalDBManagerImpl ] [08:59:25,671]: Created auto-backup of internal database "settings" in 531 ms
INFO | wrapper | 2012/03/22 09:41:50 | User logged out. Ignored.
INFO | jvm 1 | 2012/03/22 09:41:50 | WrapperSimpleApp: User logged out. Ignored.
INFO | wrapper | 2012/03/22 09:42:07 | User logged out. Ignored.
INFO | jvm 1 | 2012/03/22 09:42:07 | WrapperSimpleApp: User logged out. Ignored.
STATUS | wrapper | 2012/03/22 09:42:09 | Machine is shutting down.
INFO | jvm 1 | 2012/03/22 09:42:10 | ERROR [COMServerImpl ] [09:42:10,265]: [Wonderware] Server status check failed with error.
INFO | jvm 1 | 2012/03/22 09:42:10 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x80070005; E_ACCESSDENIED (Acceso denegado.)
INFO | jvm 1 | 2012/03/22 09:42:10 | at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:744)
INFO | jvm 1 | 2012/03/22 09:42:10 | at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:723)
INFO | jvm 1 | 2012/03/22 09:42:10 | at com.inductiveautomation.opccom.interop.opcda.impl.IOPCServerImpl.getStatus(IOPCServerImpl.java:126)
INFO | jvm 1 | 2012/03/22 09:42:10 | at com.inductiveautomation.opccom.COMServerImpl$GetStateJob.internalRun(COMServerImpl.java:791)
INFO | jvm 1 | 2012/03/22 09:42:10 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:47)
INFO | jvm 1 | 2012/03/22 09:42:10 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:566)
INFO | jvm 1 | 2012/03/22 09:42:10 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:508)
INFO | jvm 1 | 2012/03/22 09:42:10 | INFO [COMServerImpl ] [09:42:10,265]: [Wonderware] Server failure detected. Disconnecting.
INFO | jvm 1 | 2012/03/22 09:42:10 | INFO [COMServerImpl ] [09:42:10,265]: Disconnecting server 'Wonderware'
INFO | jvm 1 | 2012/03/22 09:42:10 | INFO [COMServerImpl ] [09:42:10,265]: Server 'Wonderware' state set to [CLOSED]
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [SRContext ] [09:42:10,953]: Ignition["/main", state=RUNNING] ContextState = STOPPING
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [SRContext ] [09:42:10,953]: Ignition Gateway shutting down...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: ModuleManager shutting down...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutting down module "mobile"...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [VMManager ] [09:42:10,953]: Shutting down.
INFO | jvm 1 | 2012/03/22 09:42:11 | WARN [SRContext ] [09:42:10,953]: Trying to remove servlet "mobile", but map servlet is gone.
INFO | jvm 1 | 2012/03/22 09:42:11 | WARN [SRContext ] [09:42:10,953]: Trying to remove servlet "mobiledata", but map servlet is gone.
INFO | jvm 1 | 2012/03/22 09:42:11 | WARN [SRContext ] [09:42:10,953]: Trying to remove servlet "mobileimg", but map servlet is gone.
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutdown of module "mobile" completed in 0 ms
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutting down module "udp-driver"...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutdown of module "udp-driver" completed in 0 ms
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutting down module "modbus-driver2"...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutdown of module "modbus-driver2" completed in 0 ms
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutting down module "xopc-drivers"...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutdown of module "xopc-drivers" completed in 0 ms
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutting down module "siemens-drivers"...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutdown of module "siemens-drivers" completed in 0 ms
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [ModuleManager ] [09:42:10,953]: Shutting down module "opccom"...
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [COMServerImpl ] [09:42:10,953]: COMServerImpl.Shutdown
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [COMServerImpl ] [09:42:10,953]: Disconnecting server 'Wonderware'
INFO | jvm 1 | 2012/03/22 09:42:11 | INFO [COMServerImpl ] [09:42:10,953]: Server 'Wonderware' state set to [CLOSED]
INFO | jvm 1 | 2012/03/22 09:42:11 | ERROR [NativeResourceCollector ] [09:42:10,953]:
INFO | jvm 1 | 2012/03/22 09:42:11 | java.lang.InterruptedException
INFO | jvm 1 | 2012/03/22 09:42:11 | at java.lang.Object.wait(Native Method)
INFO | jvm 1 | 2012/03/22 09:42:11 | at java.lang.ref.ReferenceQueue.remove(Unknown Source)
INFO | jvm 1 | 2012/03/22 09:42:11 | at com.jniwrapper.a.run(SourceFile:160)
And this other part
INFO | jvm 1 | 2012/03/22 10:05:45 | ERROR [COMServerImpl ] [10:05:45,765]: Error connecting OPC-COM server.
INFO | jvm 1 | 2012/03/22 10:05:45 | java.lang.Exception: Error advising subscription callback. DCOM security settings are likely preventing the OPC server from connecting to the client for callbacks.
INFO | jvm 1 | 2012/03/22 10:05:45 | at com.inductiveautomation.opccom.wrapper.subscriptions.COMSubscription.oleloop_updateGroup(COMSubscription.java:654)
INFO | jvm 1 | 2012/03/22 10:05:45 | at com.inductiveautomation.opccom.wrapper.subscriptions.COMSubscription$Connector.internalRun(COMSubscription.java:700)
INFO | jvm 1 | 2012/03/22 10:05:45 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:47)
INFO | jvm 1 | 2012/03/22 10:05:45 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:566)
INFO | jvm 1 | 2012/03/22 10:05:45 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:508)
Am I doing something wrong? what should I change to get connected without problems?
Thanks!
