When I execute inject command node red I am gettting a JSON error
Here is video explaining it.
I was actually getting a similar or same error but I never raised an issue with it. If I can duplicate it tomorrow in the office I’ll post it
try default as the tag provider
Has anybody figured out how to get igniton to work with node-red yet?
If not does anybody have any suggestions on how to control the Gpio pins on rasberry Pi
You were given an answer on another thread:
If it didn't work for you, an account of your attempt would be helpful to others. If you didn't even try, that's on you.
Has anybody been able to get node-red-contrib-ignition-nodes to work?
People have been getting the Json error (shown in video)when it executes.
I have used the git hub branch for maker but I still can get pass the Json error
When the tag value is ‘hard coded’ into the tag value field it writes to the server fine.
When it is wired up to the msg.payload of the ethernet node it does not pass the value.
Should the ethernet node be put through a change node or a function node?
If so could someone show an example of this?
I see the javascript example in the documentation that came with the flow…
Maybe yes, I should have created a different thread…Sorry guys… This was the closest and most relevant thread I could find.
For anyone who may still be facing the JSON error issue without any luck, I may have found a solution. In the Gateway webpage, go to the "Web Server" configuration and disable the option for "Force Secure Redirect" in the HTTPS settings (you'll probably have a different HTTPS port but that shouldn't matter).
