Hi friends,
We are evaluating the Ignition platform currently. What we are trying to achieve is to pull the IoT data out from various OPC-UA servers, and inject the data to AWS IoT via MQTT, using Ignition.
We have the end-to-end (south<->north) connections working. However, we can't see any other MQTT message arrives at AWS IoT core apart from the NDEATH bdseq when looking at the subscribed topic via MQTT Test client. The test source is the sample comes with the Ignition installation. We have also tried with two other OPC-UA sources without luck.
Anyone here know what configuration I have not set correctly?
