Today when i tried to launch the Ignition from the Network
i assigned my system ip as 192.168.0.250
and the other system ip as 192.168.0.251
and
I can open the Gateway status page and Launch the Project
but when i Launch the Project, after the logon page,
I receive the following error, when i launch the project
[color=#0080FF]
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 500: Unable to read response from Gateway.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:236)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:304)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:206)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:197)
at com.inductiveautomation.ignition.designer.DesignerGatewayConnection.loginDesigner(DesignerGatewayConnection.java:119)
at com.inductiveautomation.ignition.designer.DesignerGatewayConnection.doLogin(DesignerGatewayConnection.java:53)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.loginEncoded(AbstractGatewayConnection.java:465)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.login(AbstractGatewayConnection.java:460)
at com.inductiveautomation.ignition.designer.DesignerSplash.cmdLogin(DesignerSplash.java:377)
at com.inductiveautomation.ignition.designer.DesignerSplash.actionPerformed(DesignerSplash.java:353)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicRootPaneUI$Actions.actionPerformed(Unknown Source)
at javax.swing.SwingUtilities.notifyAction(Unknown Source)
at javax.swing.JComponent.processKeyBinding(Unknown Source)
at javax.swing.KeyboardManager.fireBinding(Unknown Source)
at javax.swing.KeyboardManager.fireKeyboardAction(Unknown Source)
at javax.swing.JComponent.processKeyBindingsForAllComponents(Unknown Source)
at javax.swing.JComponent.processKeyBindings(Unknown Source)
at javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
Caused by: java.lang.ClassCastException: Error trying to coerce ‘-1’ to a class java.lang.Integer
at com.inductiveautomation.ignition.client.gateway_interface.ResponseParser.endElement(ResponseParser.java:281)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:302)
… 42 more
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:646)
at com.inductiveautomation.ignition.client.gateway_interface.ResponseParser.endElement(ResponseParser.java:266)
… 53 more
[/color]
But tentative / parallelly I tried to Launch it from the Same system the gateway is installed in,
and i was able to work without any problem
please look into this problem,
Crashes as such / problem as such should be fixed before the system can be opted for production
thanks
Abdul
Automation Engineer,
AL TUWAIRQI GROUP
ISPC, Dammam,
SAUDI ARABIA
