Hi All, I have some questions about the network interface binding in Ignition, especially around redundancy.
So, Assume we have 4 subnets on the gateway, all subnets will have clients connects to the ignition gateway. There is a lot legacy reasons for this setup and we are currently stuck with it. Here is what my test results are:
- If i use subnet 1 as gateway redundancy network communication, it seems none of the clients on subnet 2-4 would be able to connect to gateway anymore.
- If i then turn off auto detect http address, and place all the subnet 1-4 in the address field, the redundancy on subnet 2-4 would not work, it will report redundant connection unknown.
At the moment, i am using a work around where i don’t specify an ip address in the redundancy interface binding field, but use server name. Then I can use client’s host file to resolve it into the corresponding subnet. Do any one have similar situation and was there a better choice in gateway settings under this situation?
