I have installed Matrikon server simulator into local machine and when i try to browse the Matrikon server from Ignition - Client ..i am not able
to get matrikon ..Can you pls help what the issue
Refer image ...at blue highlited area i suppose to see Matrikon server
Why would you expect to see anything there? I would expect you to have to enter the necessary information manually.
Also, is that an OPC-UA simulator? If it is legacy OPC, you will need to use Ignition's OPC connector.
Thanks , i got the issue resolve..i was looking at wrong location
