Ignition OEE Template
Hello,
I am new in Ignition, and I would like to know if exist any OEE template for perspective to download?
I want to sell the project in my company, and I have to start with one machine.
Regards,
Ivan Villegas
The closest to a template is buying the Sepasoft OEE modules.
Pretty much everyone else has built their own from scratch, which isn't hard, but its a bit daunting from a new to Ignition point of view.
I would also consider what does OEE mean to you versus what does OEE mean to the company? As an integrator I find that often there is a divide, very often large, between engineering, operations, and management on what this really means.
I say this because there is no cookie cutter solution. Sepasoft for an example is a system you can use to build out your production model and tie in states etc. but there is a lot of setup and design involved between making UDTs and viewing the data on meaningful screens.
My recommendation would be to identify what OEE means to the powers that be, then create a base product for them for the one machine allowing for ample room to shift if need be.
