Ignition on Docker
If we use the Docker image for running Ignition as a container, can it be used only for running Ignition Designer? Or can we also launch clients/sessions from the Ignition container?
Newbie here, I watched the demos and read the documentations, but I couldn’t find the answer- is the entire Ignition Gateway platform (Designer, Vision clients, perspective sessions) containerized ? or just the launching of Designers from the gateway containerized?
Everything is containerized.
You get the complete Ignition Gateway contained in the docker container.
