I don’t imagine there would be, but a customer of ours is concerned about installing the Ignition gateway on the same server as FactoryTalk View SE. Another company is using the Rockwell product for their PC based HMI system, while we are using Ignition. I told them it should be fine to share a server but they are looking for some reassurance.
I don’t think the Rockwell server uses the same default port as Ignition, but that would be the only thing you might need to change.
I have it running alongside Wonderware and iFix, w/ RsLinx, Kepware, and SQL server running on the same machine. No issues there.
