hi
i am currently working on one project its require to do with ignition on Ubuntu 12.04 version but am not able to install ignition after installation of java6- java1.6.0_jre can you give the suggestion please then i can proceed
thank U
hi
thank U
Can you give us more detail? What goes wrong? What messages appear? Are you using the .run installer? 32 or 64-bit machine/Ubuntu/Ignition?
I would do a clean install of just OS then from a terminal:
Then install ignition.
What command do you run to install Ignition itself? And what messages does it give you?
