Dear Ignition Support
I am fairly new to setting up OPC-UA connections and making the ignition OPC-UA Server visible to external OPC-UA clients but I am trying to setup a OPC-UA Connection from OSI-PI using their OPC-UA Connector to Ignition’s OPC-UA Server and doing some preliminary testing currently with this, but it seems something weird is being observed with certificates
Upon setting up the OSI-PI OPC-UA Connector to the correct endpoint opc.tcp://
`{IP Address or Hostname of Server}:62541, the Ignition server certificate is correctly passed to the OSI-PI UA Connector and therefore can then be manually trusted. The OPC-UA connection is setup and data is flowing between the Ignition OPC UA Server and OSI-PI via OPC-UA now but the OSI-PI certificate is not showing up in the quarantined certificates or trusted certificates in the OPC-UA Security setting of the Ignition Gateway. I have not manually downloaded the OSI-PI certificate or manually trusted it either. The security policy setup on the ignition server is set to either None, Basic256Sha256
Is this normal behaviour as I thought with OPC-UA connections both certificates are needed to be trusted at both ends before any data flow could occur regardless of security policy setup on the ignition gateway, is this correct?
Kind Regards
David Waterfield
