After I changed the password, Ignition OPC UA Server has been faulted.
I tried deleting and recreating the certs, but that didn’t fix it, I’m not sure what to do. Or why changing the password is an option if it causes a major fault.
This is the fault got
java.lang.Exception: Error creating OPC server "Ignition OPC UA Server" of type "com.inductiveautomation.OpcUaServerType" at com.inductiveautomation.ignition.gateway.opc.OpcConnectionManagerImpl.newOpcConnection(OpcConnectionManagerImpl.java:194) at com.inductiveautomation.ignition.gateway.opc.OpcConnectionManagerImpl.registerConnectionType(OpcConnectionManagerImpl.java:314) at com.inductiveautomation.ignition.gateway.opcua.OpcUaModule.startup(OpcUaModule.kt:304) at com.inductiveautomation.ignition.gateway.opcua.OpcUaModuleHook.startup(OpcUaModuleHook.kt) at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2392) at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startup(ModuleManagerImpl.java:419) at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1315) at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:306) at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:758) at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:692) at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:544) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.run(Unknown Source) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source) Caused by: java.security.UnrecoverableKeyException: Get Key failed: Given final block not properly padded. Such issues can arise if a bad key is used during decryption. at java.base/sun.security.pkcs12.PKCS12KeyStore.engineGetKey(Unknown Source) at java.base/sun.security.util.KeyStoreDelegator.engineGetKey(Unknown Source) at java.base/java.security.KeyStore.getKey(Unknown Source) at com.inductiveautomation.ignition.gateway.opcua.KeyStoreManager.getKeyPair(KeyStoreManager.kt:66) at com.inductiveautomation.ignition.gateway.opcua.client.connection.OpcUaConnectionType.createNewOpcConnection(OpcUaConnectionType.kt:54) at com.inductiveautomation.ignition.gateway.opc.OpcConnectionManagerImpl.newOpcConnection(OpcConnectionManagerImpl.java:171) ... 16 more Caused by: javax.crypto.BadPaddingException: Given final block not properly padded. Such issues can arise if a bad key is used during decryption. at java.base/com.sun.crypto.provider.CipherCore.unpad(Unknown Source) at java.base/com.sun.crypto.provider.CipherCore.fillOutputBuffer(Unknown Source) at java.base/com.sun.crypto.provider.CipherCore.doFinal(Unknown Source) at java.base/com.sun.crypto.provider.PBES2Core.engineDoFinal(Unknown Source) at java.base/javax.crypto.Cipher.doFinal(Unknown Source) at java.base/sun.security.pkcs12.PKCS12KeyStore.lambda$engineGetKey$0(Unknown Source) at java.base/sun.security.pkcs12.PKCS12KeyStore$RetryWithZero.run(Unknown Source) ... 22 more 8.1.38 (b2024030513) Azul Systems, Inc. 17.0.9
