I have Ignition 8.1.38, I try to connect Niagara 4 to Ignition but I have problem with certificate.
During connection I see under certificate Niagara 4 certificate under Quarantined Certificates, I trust this certificate but under Niagara I have this error and connection doesn't working :
SEVERE [07:40:12 02-May-24 EDT][opcUaClient.certificateValidator] Certificate C=US,ST=CA,L=Folsom,OU=,O=Inductive Automation,CN=Ignition OPC UA Server failed trust validation: Unable to construct a valid chain
INFO [07:40:12 02-May-24 EDT][opcUaClient.certificateValidator] Exemption approved for host: 10.5.1.50:62541
SEVERE [07:40:13 02-May-24 EDT][opcUaClient.client] Exception occurred during ping for device OpcUaDevice with appURI urn:localhost:OPCUA:NiagaraOpcUaClient: com.prosysopc.ua.client.ConnectException: Failed to create secure channel to server: : opc.tcp://10.5.1.50:62541 [Profile Reporting Links] ServiceResult=Bad_SecurityChecksFailed (0x80130000) "An error occurred verifying security."
Any idea ?
You’ll have to share the ignition logs and your certificate as well.
Can you upload that certificate file somewhere? DM or email it to me?
I don't see DM section, can you give me your email
It's my first name @inductiveautomation.com .
This certificate is missing a basicConstraints extension, which is a mandatory (at this time, anyway...) field for certificate used as an OPC UA application instance certificate.
You'll have to work with the vendor to generate a new one that has the required extension.
https://reference.opcfoundation.org/Core/Part6/v105/docs/6.2.2
Ok so I need to add CA flag to basicConstraints ?
Solution :
Per Section 6.2.2 of the OPC UA Reference, "Self-signed Certificates shall also include keyCertSign".
Several OpcUa server implementations have interpreted this to mean, that they should reject any certificate that does not comply. To ensure compatibility, we devised a way to make our OpcUaClient implementation use a cert with the keyCertSign usage. Since our framework is currently designed to require a password on any cert that has the keyCertSign usage, the solution requires extra steps.
- Use Niagara version 4.10u2, or 4.11u1, or newer.
- Create the cert/key pair using one of the attached scripts. gen-opc-cert.bat is a Windows batch script, and gen-opc-cert.sh is a bash script that can be run on Linux or in WSL. You can use either one, but both require that you have OpenSSL installed.
- Import the PEM file (created in the previous step) into the User Key Store of the Certificate Management Service for the host, using a password for encryption.
- In the Certificate slot on the Opc Ua Device, enter the name of the alias used for importing the cert/key above.
- Using the HTML5 Property Sheet (or the AX Slot Sheet), add a new dynamic slot on the Opc Ua Device with the slot name serverKeyPassword where the Type is baja:Password.
- Set the value of the serverKeyPassword property to be the encryption password that you specified when importing the certificate.
Note: global certificate password is a functionality introduced in Niagara 4.13. In Niagara 4.13+, this feature can be utilized instead of the serverKeyPassword property.
Script (.bat)
@echo off
where openssl >nul 2>nul
if %errorlevel% neq 0 (
echo OpenSSL not available. Please install and try again. >&2
exit /b 1
set /p hostname="Enter the client hostname [%COMPUTERNAME%]: "
if [%hostname%] == [] (
set hostname=%COMPUTERNAME%
set /p validity="Enter certificate validity in days [365]: "
if [%validity%] == [] (
set validity="365"
set /p pemfile="Enter destination file [.\client.pem]: "
if [%pemfile%] == [] (
set "pemfile=.\client.pem"
set "conffile=%tmp%\opc-cert-generator-%random%-openssl.cnf"
echo ^
[ req ]^
distinguished_name = distinguished_name^
x509_extensions = exts
echo:
echo ^
[ distinguished_name ]^
countryName = Country Name ^(2 letter code^)^
countryName_default = US^
countryName_min = 2^
countryName_max = 2^
stateOrProvinceName = State or Province Name ^(full name^)^
localityName = Locality Name ^(eg, city^)^
0.organizationName = Organization Name ^(eg, company^)^
organizationalUnitName = Organizational Unit Name ^(eg, section^)^
commonName = Common Name ^(e.g. server FQDN or YOUR name^)^
commonName_default = %hostname%^
commonName_max = 64^
emailAddress = Email Address^
emailAddress_max = 64
echo:
echo ^
[ exts ]^
basicConstraints = critical, CA:TRUE^
subjectKeyIdentifier = hash^
authorityKeyIdentifier = keyid:always, issuer:always^
keyUsage = critical, digitalSignature, nonRepudiation, keyEncipherment, dataEncipherment, keyCertSign^
extendedKeyUsage = clientAuth^
subjectAltName = URI.1:urn:localhost:OPCUA:NiagaraOpcUaClient
) > "%conffile%"
set "certfile=%tmp%\opc-cert-generator-%random%-cert.pem"
openssl req -x509 -newkey rsa:2048 -config "%conffile%" -keyout "%pemfile%" -out "%certfile%" -sha256 -days %validity%
echo error generating cert >&2
del "%certfile%" 2>nul
del "%pemfile%" 2>nul
del "%conffile%" 2>nul
exit /b 1
type "%certfile%" >> "%pemfile%"
echo Cert written to %pemfile%
