Hello community,
I created a opcua client and I want to connect it to Ignition opcua server
in Ignition opcua server settings:
I also created a user under opcua-module to be use by my client.
In the Ignition log, everytime I try to connect using my opcua-client, below is the error:
org.eclipse.milo.opcua.stack.core.UaException: no matching endpoint found: transportProfile=TCP_UASC_UABINARY, endpointUrl=opc.tcp://Henjoe-ObX:62541/discovery, securityPolicy=Basic128Rsa15, securityMode=SignAndEncrypt
at org.eclipse.milo.opcua.stack.server.transport.uasc.UascServerAsymmetricHandler.lambda$openSecureChannel$3(UascServerAsymmetricHandler.java:397)
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at org.eclipse.milo.opcua.stack.server.transport.uasc.UascServerAsymmetricHandler.openSecureChannel(UascServerAsymmetricHandler.java:387)
at org.eclipse.milo.opcua.stack.server.transport.uasc.UascServerAsymmetricHandler.lambda$sendOpenSecureChannelResponse$1(UascServerAsymmetricHandler.java:298)
at org.eclipse.milo.opcua.stack.core.channel.SerializationQueue.lambda$encode$0(SerializationQueue.java:52)
at org.eclipse.milo.opcua.stack.core.util.ExecutionQueue$Task.run(ExecutionQueue.java:119)
on my opcua-client configuration:
securityMode:
Basic128Rsa15
securityPolicy:Sign & Encrypt
username:"my username in Ignition opcua module"
password:"my password in Ignition opcua module"
uri:opc.tcp://Henjoe-ObX:62541/discovery
Note that in URI settings I also use the opc.tcp://localhost:62541/discovery but it gives me the same error.
Already accepted/trusted my client certificate under server security in Ignition opcua.
Note that I can connect to other opcua server using this client
this is the error I received from my client-opcua:
'Ignition' connect failure! Error: The connection may have been rejected by server,
Err = (_socket has been disconnected by third party)
The error from Ignition logs it's quite obvious "no matching enpoint", but I am not quite sure how to troubleshoot it.
Thanks in advance.
