Ignition Perspective 8.1.2: Language Translator - Chinese Simplified - Session Prop Code
I have searched around to find the right Session Prop code in Perspective for Chinese simplified to render these characters for language switching. Does anyone out there in the community know the correct code? (BTW: I have other languages working fine, but just can’t seem to get the Chinese Simplified to work).
Many thanks in advance to the forum gurus.
I’m no guru, but I had the same issue and found it in the user manual (sort of): See this link for a full list of valid locale tags: Java 8 Supported Locales
And I believe the item you’re looking for is “zh-CN”
“zh-Hans” is the string to use for Simplified Chinese.
