Hello, I think the screenshot below pretty summarizes the problem which is trivial but quite annoying when you create scripts on a daily basis: basically the preview only shows the first 30 or so characters even if the window is maximized and the preview behaves the same showing only part of the result.
Is it difficult to make the the binding preview adapt to the window’s width and the preview show at least 20 lines of the result or something similar?
Thank you
