Ignition Perspective Crash - Working with SVG
I am using Ignition 8.1.10, when embedding several svg’s in a perspective page (Coordinate container), I get a error message when saving. Upon restart all my work since last save is gone. It crashes about half of the times I try to save. I’m trying to make a PID using empbedded svg’s for some of the symbols.
Is this a 8.1.10 bug, of has anyone else experienced this when working with svg’s in Perspective?
error:
TimeoutException
Ignition v8.1.10 (b2021090812)
Java: Azul Systems, Inc. 11.0.11
Full:
java.util.concurrent.TimeoutException
at java.base/java.util.concurrent.CompletableFuture.timedGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:484)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:67)
at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.commit(ResourceEditor.java:166)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.commitAll(TabbedResourceWorkspace.java:331)
at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.notifyProjectSaveStart(ViewWorkspace.java:317)
at com.inductiveautomation.perspective.designer.DesignerHook.notifyProjectSaveStart(DesignerHook.java:418)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.commitAll(IgnitionDesigner.java:1593)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.handleSave(IgnitionDesigner.java:1358)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleSaveAction(IgnitionDesigner.java:2773)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$5.actionPerformed(IgnitionDesigner.java:2360)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
how many embedded svgs are we talking about? and how complex are they?
are you running any scripts on them?
At the moment 8 svg’s, created in inkscape. Not very complex
oke they dont look to complex but did inkspace make them complex? can i see the sourcefile?
how did you import the svgs?
svg’s source files? DM
are they being used as img?
No, embedded
I don’t think it’s your SVGs. We’ve had this as well in both 8.1.7 and 8.1.9. Just randomly a save takes ages and then we get that timeoutexception error and can no longer save anymore. Have to reboot designer. Quite annoying
I’v seen this earlier, but after a restart of the designer it’s normally OK. But this time it happens over and over again, after restarts…
i dont see anything special about the svgs so its probably elsewhere yea.
