Ignition Perspective dynamic valve
Looking for some help or ideas for a simple application. Trying to show a three way valve that I can dynamically color based upon flow. It could be as simple as three triangles with two colored green to demark direction of flow. Without simple drawing tools I am at a loss. I found a working example in the symbol factory but am struggling to dynamically color only certain portions.
Which symbol did you use? (can you share a picture?) and what portion do you want to change color on?
You could also use a import a custom SVG.
