I’m trying to convince a customer to switch over to Ignition. They are afraid to do this in 1 big step.
I would like to convince them to already migrate a part of the application to show them how smooth Ignition is.
They have an embedded web viewer where I could display an Ignition page in their current application.
The problem here is, every time the embedded view is opening, the Ignition resource loading page popups up.
No, Perspective is a single-page application--the entire project has to load at the start. And view and page navigation within it doesn't use HTTP any more.
Your embedding technique is not maintaining cookies or session state to keep the project "alive".
If the embedded browser is always there loaded, it should keep it alive. Can you have the embedded browser component always there, even if it’s hidden or moved off the field of view, and then visible when you want to show it? You havent said what their existing scada is
