Hello, I cannot find an example of how to tie a mouse click in Perspective to an EVENT DRIVEN query tag. Can you link me to an example for this?
David
What do you mean by “tie a mouse click to a query tag”? Do you mean you want the mouse click to update the tag/refresh the query?
Event driven expression or query tags are updated when a referenced parameter changes. If there’s no outside parameter referenced, they never update. If the updates you wish to perform are always triggered by scripting, consider using a memory tag and have the scripts compute and write the new value as needed.
Thank you. I will look at doing an expression to update a memory tag and see if that works well. I will need to set a flag high and then off so it can be run again. Any suggestion on that?
Hi David,
Let’s back up for a moment and tell us what your looking to do. There may be another way than using an expression to get to where you want to go.
There may be some hints in the following train of forum answers, specifically 5 of 8 and 8 of 8 (colon would possibly produce an emoji here ) do add the letter h to this URL so that it is NOT just seen as the first message of 8: ( add the letter h in your browser before this )
ttps://forum.inductiveautomation.com/t/pdf-viewer-event-handlers/26795
Yes, they were looking at PDF- not Query- yet the mouse click in Perspective is examined.
Post #8 (the last one) may help most of all.
Hello, what I am trying to do is this.
Event driven is based on a change within the text of the query or a value passed to the query. You have static query text and values, so you can’t use event driven.
Run the query in a script function instead, saving the result to your tag (as a memory tag). Call the script function whenever you want.
I need the values to be refreshed in a Table. I do not want to use Named Query. My issue is tying the data from the SELECT to the Table.
Your mouse click event runs a script. That script runs the query via system.db.runQuery(). (Doesn’t have to be a named query.) The script writes the query results dataset to the memory tag. A side effect of writing to the memory tag will be updates to any component (Vision or Perspective) bound to it (like the data property of your table).
