Ignition Perspective Pipe line water flow animation
Hi i want to animate Perspective Pipe lines look like water flowing, based on Boolean and Int tags. Please share your ideas Thanks.
What exactly are you looking for? Something like this,
Yes Exactly like this, In ignition perspective. can you share the procedure.
I’m not the best to ask on this, perhaps @victordcq has a better approach. But here is an example (not quite like the one above), paste this into a View.
    "type": "ia.shapes.svg",
    "version": 0,
    "props": {
      "viewBox": "0 0 149.36 96.872",
      "elements": [
          "elements": [
              "d": "m21.458 92.737v93.996l48.249 0.3574v-57.542h44.675v30.736c51.823 0.3574 51.466 0 51.466 0",
              "fill": {
                "paint": "#C0C0C000"
              "name": "path1193",
              "stroke": {
                "paint": "#4ECD57",
                "width": 5
              "type": "path"
          "name": "layer1",
          "transform": "translate(-18.958 -92.737)",
          "type": "group"
      "style": {
        "classes": "lineMove"
    "meta": {
      "name": "Line_1"
    "position": {
      "x": 140,
      "y": 436,
      "height": 220,
      "width": 386
    "custom": {}
Here is the CSS
.psc-lineMove {
  stroke-dasharray: 10;
  stroke-dashoffset: 10;
  animation: dash 20s linear infinite;
@keyframes dash {
  from {
    stroke-dashoffset: 0;
  to {
    stroke-dashoffset: 1000;
@jlandwerlen Thanks for your support, Could please give me the brief idea about this.
Seems good, i dont really do much with animations, but this is probably the way to go.
Hi, I was trying to paste the json script to a new using Shift + right click + paste jason, but looks like the format is incorrect with additional square bracket, but after removing the square bracket and import, it show blank screen.
Sorry, not sure why I did it that way, but just paste into an opened view.
Here is the JSON
  "custom": {},
  "params": {},
  "props": {},
  "root": {
    "children": [
        "meta": {
          "name": "Line_1"
        "position": {
          "height": 220,
          "width": 386,
          "x": 156,
          "y": 208
        "props": {
          "elements": [
              "elements": [
                  "fill": {
                  "name": "path1193",
                  "stroke": {
                    "paint": "#4ECD57",
                    "width": 5
                  "type": "path"
              "name": "layer1",
              "type": "group"
          "style": {
    "meta": {
      "name": "root"
    "type": "ia.container.coord"
