Ignition Perspective Project Double Logging to SQL
I have a project that is working fine and running as it should except for it seemed to be double logging to our SQL server.
I am looking into if this could be cause by somewhere inside of the perspective pages/scripting but I just wanted to make sure that my transaction groups aren't causing this for some weird reason.
Here are the settings for my transaction groups:
Any information is helpful!
First, make sure you did not create your transaction group in a project that is inheritable. If so, the transaction group will run in each child project that inherits from the parent.
Just checked and the project is not inheritable.
Maybe try with Reset trigger after execution unselected. I think this setting is trying to reset the trigger tag to 0, but it's read only so it reverts to back to 1.
I tried that out and that doesn't seem to be the issue either. The value seems to reset the trigger correctly back to 0 when the "Reset trigger after execution". I tried turning it off and that value stays 1 and won't continue to log.
Another thing I am finding that is curious is all of the repeat logs are logged at the exact same time:
Not sure if this helps in anyway, but it makes me think that something weird is happening that is not script/Perspective related.. If it were script/perspective related, I would imagine the trigger would be turning on then off then on then off again, resulting in two logs at different times..
Go to the gateway β†’ Status β†’ Systems β†’ Transaction Groups and verify that you do not have multiple copies of the same group running.
Thought I checked that, but after double checking I think that was the issue. I had a backup copy of the program with active transaction groups.. I turned them off, saved, and will start to monitor the SQL data to make sure that was the issue.
Kicking myself for overlooking that... thanks for the help!!
Can you mark the post as solved?
Just did, sorry about that
