Ignition Perspective Theme variables.css Modifications Get Overwritten
I have been modifying the variables.css files for each theme in perspective to add more colors to the themes than just the default.
However, the variables.css file gets ‘reset’ to the default every once in a while (at 1:00 am, when none of our engineers are developing). All of my changes get lost and my perspective session looks terrible because color variables aren’t defined anymore.
Any ideas why this might be happening/how we can fix this?
FYI, I am using this approach because I found it in the Ignition Manual:
https://docs.inductiveautomation.com/display/DOC80/Perspective+Themes
That timing is extremely suspicious. Can you replicate the same behavior if you restore your .gwbk on a local development machine? Is it possible your IT group is restoring files/taking a VM snapshot/etc at 1 every night?
I will dig into that avenue. As far as you know, modifying the variables.css file is the right approach to add more color variables to themes?
I just found an old forum post about 8.0.13 discouraging the modification of default themes.
As far as I know, yes, though I’m far from an expert on Perspective :slight_smile:
The documentation seems to agree with us:
https://docs.inductiveautomation.com/display/DOC80/Perspective+Themes#PerspectiveThemes-ThemeColors
Ok. Thank you. I will see what our IT group says.
