Ignition Perspective Unable to Load in Browser
Ignition Perspective keeps blocking my attempts to open a Perspective Page in a url web browser. It says that "No Identity Provider Configured", but that is not true. It also says I must log in to continue onto the page, but the login button is greyed out and unusable. When I try to force a logout and log back in, now my previously accepted password is invalid.
I'm kind of at a loss as to what is happening.
Could you share some images of the error?
I see this error when I open the project properties in Designer.
When I try to launch a page from Perspective in a URL I see this:
I believe I solved my own issue. I had to reboot the Ignition Gateway and re-add the IdP parameters, and it worked. Something was bugged it looks like.
I ran into this as well. All of the sudden I couldn't log in and it said I have no identity provider configured even though I do. What do you mean by "re-add the IdP parameters?" I'm just using the default provider. I've tried restarting the Gateway and it's still not working.
Edit: Never mind, I figured it out. In the project settings I just had to point it back to the correct Identity provider:
