Ignition Perspective XY Chart Zoom
I am working with an XY chart and would like to be able to zoom into different areas like you can with a power chart. There is an older forum post (~1 year) that said:
"Zoom or Pan functionality in the Perspective XY Chart, it isn't enabled by default, but it is fully supported. Since the XY Chart is built on the amCharts 4 library, you can configure the cursor properties to change how user interaction works"
There is no cursor.behavior property that is natively exposed to edit, and I tried adding a value with the behavior key, but that didn't work. Any help would be greatly appreciated, whether it be me misunderstanding this property or a work around, thanks!
