Ignition play as modbus server
I want to set the ignition edge as the modbus server(slave), then I can set aside some memory, so the client can access the server via modbus tcp protocol.
Is it possible? Does igntion have a module to play as the modbus slave/server?
{ @chaoling has already found my Advanced Modbus module and contacted me offline. }
Thank you Phil for the help.
How can I use this module if I have one Main Gateway and other one as Redundancy?
What are you expecting to happen or be different with redundant gateways?
