Ignition props interprets script return wrongly
Hi all,
Little unsure how to search for an answer for this!
I've got a property binding that I want to return an array of objects (esentially a dataset... but I want it in JSON form, not a dataset)
The script returns the correct structure, but ignition puts it as a string.
If I copy and paste the data, it formats it correctly
How do I ask ignition nicely to recognise the structure? (Noted the array length changes)
Binding is as follows:
Thanks!
:smiley:
Don't use json.dumps. That's what is creating the string. Just return the jython list of jython dictionaries. Perspective will accept that as an array of objects.
Could have sworn I tried that earlier ... Home time I think!
Thanks @pturmel ! :smiling_face:
You might also like my Integration Toolkit's solution:
forEach(
	{this.custom.selectedCylinderIds},
	it()
Just an expression binding, no transform, no jython overhead.
Thats super useful to know thanks!
I've just installed the Integration Toolkit yesterday, but havent yet fully got to grips with how I use all the functions! Need to have a detailed read of the docs with a coffee.
I wont derail this thread too far, but I was trying to work out how to call a script that passes an array into it as a parameter. Then do this conversion on the output. The screenshot in my original post has a 'value' parameter of [1,4,6] or [2,4,7,8,9] etc
Oh, I see. That would be an inner join. Also part of my Integration toolkit. (Could also be done with asMap() and where().)
