I am on the hunt for a SCADA package that would suit my needs, i.e. looking for a self-contained redundant supervisory system with some data handoff links to external historian / DCS (as required).
The key here is redundancy: redundancy in the networks to the field device and redundancy in the communications link between the servers/external devices.
- Field Device Communications Links Redundancy
Most field devices will communicate using Modbus TCP or Modbus RTU-over-TCP. Each field device will have two network ports and will be connected to different networks (different subnets).
As far as I can see Ignition does not support such a functionality out-of-the-box (redundant links to the same device). But I assume that with some scripted tag name manipulation, I would be able to switch between the tags from either of those links, based on the link status? Or is there a better way to do it? - Server-to-Server Redundancy
I would like to run two network cables between the two Ignition Gateway nodes, each on its own dedicated subnet. But again, this does not appear to be supported?
Do I have to use port teaming in this instance? Or could I still use two separate networks and then configure hosts file (on Windows) accordingly? Note that this system will not have a DNS server configured (unless absolutely necessary), hence why using hardcoded entries in a file. - Database Server Redundancy
Assume that the easiest way of maintaining a redundant link to the SQL server is to implement two separate networks and then either use a DNS server or hardcoded hosts file entries.
Or is SQL database link redundancy supported natively by Ignition?
Just trying to determine what would the best approach be for maintaining redundancy with minimal hardware and/or effort. Since I have little experience with Ignition, I do not want to over-engineer anything.
Essentially the system has to survive the loss of a single network and/or a single server.
Would architecture similar to the one shown on the attached drawing work? Or is there a better/easier way to achieve it?
