Ignition Report issue with key browser
I have been building a 46 page report and now that i have mapped all of the data in it i went to check to see if everything was reporting as it should. i noticed that i was getting zeros for all my historical data and upon further inspection my start and end dates were improperly configured.
i corrected those start and end dates but now I'm getting 2 new issues I’m getting this error whenever I open the designer
And this issue when I open the preview
now I'm not getting any data at all and i do not see my parameters or queries in my design mode
i switched my start and end dates back to standard but still no luck
if anyone has any insight that would be helpful.
(also i one point i did add and then remove 2 parameters that are no longer pointing at anything and are not in the report anymore)
Thank you.
potentially solved after writing all this out, i may have to much information in a single report
The designer (and vision clients) operate with a hard-coded 60-second timeout on gateway requests. If your report takes that long to run, it will break in the designer.
Note that this is typically caused by poor database design/indexing or terrible SQL query design. If historian queries, verify that you have indices on the data partitions.
