Ignition Reporting Giving Errors After Upgrade
I am pulling data from an OSI PI database to show in a report. Everything was working fine in Ignition 7.9. We upgraded to 8.1 and now when the reporting queries data in the designer I get errors and the report sends with no data.
Error From Report Designer
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: class com.osisoft.rdsa.DataReader (in unnamed module @0x7871eab) cannot access class sun.nio.ch.DirectBuffer (in module java.base) because module java.base does not export sun.nio.ch to unnamed module @0x7871eab
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at java.desktop/javax.swing.SwingWorker.get(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.done(SampleData.java:145)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: class com.osisoft.rdsa.DataReader (in unnamed module @0x7871eab) cannot access class sun.nio.ch.DirectBuffer (in module java.base) because module java.base does not export sun.nio.ch to unnamed module @0x7871eab
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:930)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
at jdk.proxy2/jdk.proxy2.$Proxy56.getReportData(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:135)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:112)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.IllegalAccessError: class com.osisoft.rdsa.DataReader (in unnamed module @0x7871eab) cannot access class sun.nio.ch.DirectBuffer (in module java.base) because module java.base does not export sun.nio.ch to unnamed module @0x7871eab
at com.osisoft.rdsa.DataReader.setCurrentRow(DataReader.java:124)
at com.osisoft.rdsa.DataReader.next(DataReader.java:75)
at com.osisoft.jdbc.ResultSetImpl.next(ResultSetImpl.java:228)
at org.apache.commons.dbcp2.DelegatingResultSet.next(DelegatingResultSet.java:1160)
at com.inductiveautomation.ignition.gateway.datasource.DelegatingResultSet.next(DelegatingResultSet.java:424)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement$ResultSetWrapper.next(SRConnectionWrapper.java:894)
at com.inductiveautomation.ignition.gateway.datasource.BasicStreamingDataset.(BasicStreamingDataset.java:102)
at com.inductiveautomation.ignition.gateway.datasource.BasicStreamingDataset.(BasicStreamingDataset.java:49)
at com.inductiveautomation.reporting.gateway.data.queries.PrepStmtQuerySource.executeQuery(PrepStmtQuerySource.java:93)
at com.inductiveautomation.reporting.gateway.data.queries.PrepStmtQuerySource.query(PrepStmtQuerySource.java:51)
at com.inductiveautomation.reporting.gateway.data.queries.PrepStmtQuerySource.query(PrepStmtQuerySource.java:28)
at com.inductiveautomation.reporting.gateway.data.QueryReportDataSource.gatherData(QueryReportDataSource.java:64)
at com.inductiveautomation.reporting.gateway.ReportingGatewayHook.getReportData(ReportingGatewayHook.java:480)
at com.inductiveautomation.reporting.gateway.ReportingGatewayHook$RPC.getReportData(ReportingGatewayHook.java:583)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(null)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:167)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
at java.lang.Thread.run(null)
Ignition v8.1.39 (b2024040909)
Java: Azul Systems, Inc. 17.0.10
Can someone shed some light on this error?
I think you need a newer version of the JDBC driver you’re using to connect to PI.
Did you get this to work?
The drive has not been updated yet. In my company updating this driver falls under ITs responsibility and I'm just a controls guy. I will update this post when the drive is updated.
Does anyone know where to get an up-to-date version of this JDBC driver?
I'm not sure if there's a way to get the file by itself directly from https://my.osisoft.com/
What I did in the past was install PI JDBC 2016 (not sure if there's a newer version available)
Then grab the jar file from C:\Program Files (x86)\PIPC\JDBC\
Edit:
Actually, I might have installed PI SQL Client JDBC 2021
Then grabbed the jar file from C:\Program Files\PIPC\SQL\SQL Client\JDBC
I can't remember that far back :sweat_smile:
I was correct at first
