Ignition reports module: From scheduler send a report on trigger, from a tag change
Hello,
In Ignition reports, you have scheduler where you can send or save reports. However there is only a option to create a trigger on a certain time. In my case is it needed to send a report when a tag value change.
Is it possible to send a report where the trigger is a change of a tag value?
Any help appriciated
Yes, create a tag change script and use the system.report.executeAndDistribute() function to run your report.
https://docs.inductiveautomation.com/display/DOC81/system.report.executeAndDistribute
Highly recommended this is done on a Gateway Tag Change Event as the function can be blocked.
Thanks Irose,
I have it working now
