Hello, although I suspect it’s not the intended Linux target, Ignition runs just fine on SuSE Leap 15.3 in a virtual machine (KVM/qemu).
- Headless install (command line) was fine after creating the user and group
ignition:ignition. -
fontconfigwas already installed. - Needed to install
sysvinit-toolsto obtainpidof(required to successfully launch the application after installation).
Connectivity from the host operating system was initially blocked by firewalld, which I disabled (along with AppArmor). This manifested as the VM returning an ICMP host unreachable.
No systemd service file was installed so I created one. If you examine the contents you will see that it has a second commented out mode besides forking. In the other mode it runs in the console, and you can monitor the logging with e.g. journalctl -uignition -f. I don’t know which one is best, it would be nice if there was an official service file.
I’m apparently unable to attach the service file, so here it is:
[Unit]
Description=Ignition SCADA
After=network.target
# cat ignition.service
[Service]
User=ignition
Group=ignition
Type=forking
ExecStart=/usr/local/bin/ignition/ignition.sh start
ExecStop=/usr/local/bin/ignition/ignition.sh stop
# There is also a console mode
#Type=simple
#ExecStart=/usr/local/bin/ignition/ignition.sh console
[Install]
WantedBy=multi-user.target
