Ignition sample projects/ additional components in Perspective
Hello,
I am newbie to Ignition.
Just wondering if I can find somewhere example project to be used for learning of system.
I am thinking to create Solar Plant wisualisation. I need to use advanced way of user management and displaying of charts and trends. I need it more advanced than Perspective components available.
I have no clue if I can get/buy some extensions which can fulfill my needs
Best Regards
Marcin
You should browse all of the projects that the community publishes on the Ignition Exchange.
It's true, the Ignition Exchange is great and getting better all the time.
Here are some other things I think you should also check out.
When you install Ignition it lets you start from scratch or load a sample project. You can load a sample project to get an idea of how projects are laid out. Keep in mind visualization in Ignition can be either Vision module or Perspective module and they are very different (and both very good).
I would strongly recommend checking out Inductive University. Just create an account and start watching videos on any topic you're trying to learn more about. They're continually adding to the lessons on IU with > 70 new videos planned for 2025.
It's also helpful to search the manual anytime you need more information about how something works.
Also, it is ALWAYS good to search this forum any time you're stuck on something. The search is fantastic on this forum and pretty much any problem you will encounter has been solved here with the solution easily searchable.
