Ignition Script NT Credential Auth Http Post 500 Error Invalid Request Format application/xml
I am attempting to perform an HTTP Post on some XML data using domain-based authentication periodically from an Ignition gateway script. My larger task is to run a HTTP get to retrieve tabular data, parse it, update/insert database rows based on the HTTP get result, update a status field in each row of the HTTP get table, and then run a HTTP post on the modified XML HTTP get body. The changes to the HTTP get xml data consisted of replacing values of "SENT" with one of the following values: "SUCCESS", "ERROR: Result is null", or "ERROR: Duplicate LINKID and Sampled Date combination in API call, this row was ignored".
This post contains the code used for the HTTP get: Script Console cryptography for HttpNtlmAuth requests.get Import Error - Ignition - Inductive Automation Forum.
See below for post logic, with dummy values for the function parameters. The XML content is a raw python string, including insignificant whitespace (also tried without insignificant whitespace) with no special encoding. My output with and without insignificant whitespace is as follows:
{'code': 500, 'body': 'System.InvalidOperationException: Request format is invalid: application/xml.\r\n at System.Web.Services.Protocols.HttpServerProtocol.ReadParameters()\r\n at System.Web.Services.Protocols.WebServiceHandler.CoreProcessRequest()\r\n', 'status': HTTP/1.1 500 Internal Server Error}
Since I only modified one string field in each table row as described above, I am pretty sure this is not an issue with my XML content. My suspicions are either character encoding/string entity handling or a server error.
Please advise.
HTTP Post Logic
def getNTClient(username, password, domain):
	# Helper function to get http client
	from org.apache.http.auth import NTCredentials, AuthScope
	from org.apache.http.impl.client import HttpClientBuilder, BasicCredentialsProvider
	credProv 	= BasicCredentialsProvider()							# Build credentials provider
	ntCred		= NTCredentials(username, password, '', domain)		# Build NT domain credentials
	credProv.setCredentials(AuthScope.ANY, ntCred);					# Set credentials
	bld 		= HttpClientBuilder.create()							# Create HttpClientBuilder
	return bld.setDefaultCredentialsProvider(credProv).build()			# Build client with credential provider
def getResultBody(result):
	from org.apache.http.util import EntityUtils
	return str(EntityUtils.toString(result.getEntity(), 'UTF-8'))
def postXml(url, username, password, domain, body):
	from org.apache.http.client.methods import HttpPost
	from org.apache.http.entity import StringEntity
	client	= getNTClient(username, password, domain)
	post	= HttpPost(url)
	post.setEntity(StringEntity(body.encode('utf-8')))
	post.setHeader("Accept", "application/xml")
	post.setHeader("Content-Type", "application/xml")
	post.setHeader("charset", "utf-8")
	res		= client.execute(post)
	sts		= res.getStatusLine()
	od		= {'status' : sts, 'code' : sts.getStatusCode(), 'body' : getResultBody(res)}
	client.close()
	return od
url		= 'MY URL'
un		= 'MY USERNAME'
do		= 'MY DOMAIN'
pwd		= 'MY PASSWORD'
body	= 'MY XML BODY'
outpostXml(url, un, pwd, do, body)
print out
Apologies for the vague question. Didn't want to share the xml data or some of the parameters in the URL out of concern for client privacy. Resolved it, and posting code so the next guy doesn't have to spend hours figuring this stuff out.
I ended up putting a TaskGuid parameter specific to this API, which I included directly in the URL for the get, and the insignificant whitespace stripped XML body of the post (no special encoding) into a Java ArrayList and then setting the entity of the post as a UrlEncodedFormEntity using the parameters ArrayList. My URL for the get had the form
https://[host]/[method]?TaskGuid=[getTaskGuid]&Parameters=
(no "Parameters" in URL) and the URL for my post had the form
See updated postXml function. The getNTClient and getResultBody functions stayed the same.
Updated postXml Function
def postXml(url, username, password, domain, guid, body):
	# guid:		TaskGuid parameter to use for post
	# body:		PyString containing XML to use
	# Import libraries
	from java.util import ArrayList
	from org.apache.http.message import BasicNameValuePair
	from org.apache.http.client.entity import UrlEncodedFormEntity
	client	= getNTClient(username, password, domain)		# Construct client
	post	= HttpPost(url)									# Construct post
	params	= ArrayList()									# Construct ArrayList
	params.add(BasicNameValuePair('TaskGuid', guid))		# Add TaskGuid parameter to ArrayList
	params.add(BasicNameValuePair('Parameters', body))		# Add Parameters parameter (XML Body) to ArrayList
	post.setEntity(UrlEncodedFormEntity(params))			# Set post entity
	res		= client.execute(post)							# Execute Post
	sts		= res.getStatusLine()							# Get status line
	# Build output dictionary
	client.close()	# Close client
	return od
