I need the SDK for this version. When I go to the download section of the Inductive Automation web site and when I choose the 7.6.7 in the archives, the download link for the 7.6.7 sdk is empty, the more recent sdk I can download is 7.6.6
Can I use the Ignition 7.6.6 sdk with a 7.6.7 version ? if not where do I find the sdk for this version ?
I think you need to compile and run using Java 6 when building modules for Ignition 7.6 and prior. Something about the pack200 format changed for Java 7 or Java 8…
I have tried with jre6 but Eclipse told me that 1.6 was not supported
Therefore, I have tried with JRE7 and it seems to work !
No more error when launching the designer !
Thanks!!
