Ignition SDK Module Creation
Facing difficulties while creating a maven sdk project in eclipse for ignition version 7.9 or below.
Do any one has example or link on project creation on eclipse?
Have you already seen the SDK docs? https://docs.inductiveautomation.com/display/SE/Setting+up+your+Eclipse+Environment
I’ve only used intellij so I can’t speak to the set up process for eclipse.
Once you go through the initial set up, the skeleton project is set up for you.
Also check out the git repo for completed projects.
