Ignition SDK Training Project Build Failure - Plugin 'io.ia.sdk.modl' version '0.1.1' Could Not Be Resolved
Hi Everyone,
I am trying to build the Ignition SDK training project scripting-function-g, but the build fails during plugin resolution.
Environment
java -version
openjdk version "11.0.32" 2026-07-21 LTS
OpenJDK Runtime Environment Zulu11.90+19-CA (build 11.0.32+9-LTS)
OpenJDK 64-Bit Server VM Zulu11.90+19-CA (build 11.0.32+9-LTS, mixed mode)
gradle
gradle -version
Gradle 9.7.0
Build time:    2026-08-06 14:07:35 UTC
Revision:      3defbfc59d757b873d787b2261de5c7f8a00970a
Kotlin:        2.4.0
Groovy:        4.0.32
Ant:           Apache Ant(TM) version 1.10.17 compiled on April 6 2026
Launcher JVM:  11.0.32 (Azul Systems, Inc. 11.0.32+9-LTS)
Daemon JVM:    C:\Program Files\Zulu\zulu-11 (no Daemon JVM specified, using current Java home)
OS:            Windows 11 10.0 amd64
Project:
  • Ignition SDK Training Project
  • Module: scripting-function-g
Error:
Build file 'C:\Users\ABC\OneDrive -Company\Documents\08_IgnitionSDK\ignition-sdk-training\scripting-function-g\build.gradle.kts' line: 10
Plugin [id: 'io.ia.sdk.modl', version: '0.1.1'] was not found in any of the following sources:
- Gradle Core Plugins (plugin is not in 'org.gradle' namespace)
- Plugin Repositories (could not resolve plugin artifact
  'io.ia.sdk.modl:io.ia.sdk.modl.gradle.plugin:0.1.1')
Searched in the following repositories:
- Gradle Central Plugin Repository
- https://nexus.inductiveautomation.com/repository/public
build.gradle.kts:
plugins {
    id("io.ia.sdk.modl") version("0.1.1")
settings.gradle.kts:
pluginManagement {
    repositories {
        gradlePluginPortal()
        maven(url = "https://nexus.inductiveautomation.com/repository/public")
Despite having both the Gradle Plugin Portal and the Inductive Automation Nexus repository configured, Gradle is unable to resolve the io.ia.sdk.modl plugin.
Has anyone encountered this issue recently with the Ignition SDK training examples? Are there any additional repository settings, plugin version updates, or Gradle/JDK compatibility requirements that I should be aware of?
Any guidance would be appreciated.
Thank you.
Something in your environment?
plugins {
This is already added in file build.gradle.kts
This is the first time I'm getting my hand on module development.
Yeah, my point is that your Gradle output is saying it looked in the gradle plugin repository for that plugin/version and couldn't find it, but it's right there.
Try ./gradlew tasks --debug to get fully verbose output?
