Hi, I currently have a window that contains a table and a datetime slidebar object.
The table is populated with data using SELECT and the timeframe from the slidebar.
That part is working OK.
Next , I want to search for a particular serial number from the db. I know how to built the query ( SELECT * FROM mydb WHERE SerialNumber = ‘123456’ ), I just not sure what to do next.
Should I add/need a button to open another window? and a new window will contain input box and a table?
You can simply put the text box on the same window as the table and your query can be something like:SELECT * FROM mydb WHERE SerialNumber LIKE '%{Root Container.Text Field.text}%'You could also do it through the use of multiple windows but it just means more work.
You just add another condition to your where clause:SELECT * FROM mydb WHERE mydb.t_stamp BETWEEN '{Root Container.Date Range.startDate}' AND '{Root Container.Date Range.endDate}' AND SerialNumber LIKE '%{Root Container.Text Field.text}%'
If you’re looking to keep the table to display all the data when noting in entered, you can concatenate your query-- or portions of it into a string.
Next, add a dynamic property to the text field called where. This will become clear in a moment. Bind where to the expression:
IF({Root Container.Text Field.text}="","",concat("AND SerialNumber LIKE '%",{Root Container.Text Field.text}%,"'")
This should give you the rest of the where clause to append to your query, if needed.
Next, make a dynamic property for the table called query (pretty creative, right?) and use the expression:
concat("SELECT * FROM mydb WHERE mydb.t_stamp BETWEEN '",{Root Container.Date Range.startDate},"' AND '",{Root Container.Date Range.endDate},"' ",{Root Container.Text Field.where})
Last bind the data property of the table to query, and you should be good to go.
Yes, I do want to keep the table display all data when nothing is entered.
I tried to bind where to the expression but got syntax error on token ‘COMMA’ ( Line1, char 110)
Absolutely right. good catch. My eyes start to cross looking at all the single and double quotes.
I read somewhere a line that says “Make it possible for programmers to write in English, and you’ll find out that programmer’s can’t write in English”.
